bigger evo
Old Aug 22, 2014 | 08:34 AM
stumpy13's Avatar
stumpy13
6th Gear
Default bigger evo
opinions needed i have a 94 Electra glide i have a chance to get a 120" m/p top end for pretty good price used of course but i can clean it up i know i have to cut the cases for cylinders but wondering about balancing fly wheels and what else im going to get into so far its a stock motor with ev 27 cam and dyna 200 i ignition
Old Aug 22, 2014 | 08:58 AM
grbrown's Avatar
grbrown
You really need to give us more details of the parts you are talking about! A stock Evo cannot be made as big as 120", the parts are simply not available to do that. The crankcases cannot be bored by very much, as a twincam can, for example, so increased bore size is very limited. With increased stroke in stock cases it is possible to get a little over 100", but the cases really are not man enough.
Just what is this '120" m/p' top end and what has it come off?
Old Aug 22, 2014 | 09:05 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I believe that the internals from a Merch 120" engine require a raised-deck case to accomodate the large bore/piston configuration.
Largest bore your OEM cases can accept is a 3.812", and over a 4 5/8" stroke you can have a 106", or with a 5" stroke(not really suggested with a sock case if wanting to "lean" on it) it could be 114".
Scott
Old Aug 22, 2014 | 10:12 AM
stumpy13's Avatar
stumpy13
6th Gear
i was told its a merch performance cylinders pistons rings and heads that fit an evo motor thats bout all i know so far ill have to check and see what bore size is
Old Aug 22, 2014 | 10:41 AM
grbrown's Avatar
grbrown
Merch was a Canadian company who made scratch-built Evo style engines, up to 131" IIRC. I don't believe they are still around today. Bore size will certainly tell us if they will fit stock cases.
Old Aug 22, 2014 | 02:03 PM
Hillsidecycle.com
Sponsor
A 97" Evo can be had easily.
95 hp and 105-100 ft/lbs.
Scott
Ozark Joe
EVO
33
Dec 29, 2020 03:57 PM
motohead20
EVO
Apr 15, 2013 12:21 AM
Rockwool
Screamin Eagle CVO Models
Feb 10, 2013 11:11 AM
travistodd1
Engine Mechanical Topics
Jan 25, 2013 04:32 PM
stevepacman
Exhaust System Topics
Sep 26, 2008 09:21 AM
