clutch cable routing
Old 09-05-2014, 02:56 PM
SeaZund's Avatar
SeaZund
SeaZund is offline
Default clutch cable routing
I've got a 1980 shovel FLT that the PO replaced the shark fairing with what appears to be an early 90's batwing fairing. I'm replacing the clutch cable and I've got questions about the correct routing of the new cable. I've got a 84-90 service manual, but I don't find any details about this. It appears at the tranny end that it must route behind the push rod tubes.
1) would it also go behind the lower carb bracket? (Pic shows it in front, but I'm thinking it needs to be behind the brace)
2) over or under the engine guard?
3) outside of, or between the frame downtubes? Between the downtubes looks like it'd put the cable right up against the front exhaust pipe.
4) lastlly, does it exit the fairing below and in front of the lower fork tree (as shown in the pic), or between the trees? If between the trees, which side of the neck? Appreciate the help
Attached Thumbnails clutch cable routing-1.jpg   clutch cable routing-2.jpg   clutch cable routing-3.jpg
Old 09-05-2014, 03:43 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,707 Likes on 1,343 Posts
Well, lemme see if I can help some. On my bike, it goes through a hole in the faring, then loops down on the left side of the neck, along the left side of the cylinders though a standoff bracket, ending about at the rear of the block in a bracket with the adjustment nuts, which then points the cable over to the arm. Don't think I have a pic.
Old 09-06-2014, 02:49 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Thumbs up
I had to do a search to check, but if the clutch actuation lever is on top of the trans cover and you look at this photo, your route sounds and looks right.
Old 09-06-2014, 02:58 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Jeez Graham,
Nice find on that old shovel battle cruiser photo. You are a resourceful chap! If you're ever in the northeast part of the States lemme know. I'll buy you a drink we won't consume as we'll have some miles to put down. Lol
Tom
Old 09-06-2014, 03:03 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Hey OP,
A pal of mine just sold a Shovelhead FL with a moco batwing, I think it was stock anyway. Are you sure it started its life as a FLT?
Old 09-06-2014, 04:37 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Yeah, that's an 86 to something batwing on there. 85 back were different.
Old 09-06-2014, 05:07 PM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Originally Posted by Tee⋁13188174
Jeez Graham,
Tom
Aw shucks - ya shouldn't! Oh alright, I'll have a.....
Old 09-07-2014, 03:05 PM
SeaZund's Avatar
SeaZund
SeaZund is offline
Originally Posted by Tee&Vee
Hey OP,
yes, the front exhaust (sorry for the fuzzy pic) and key are both 1980 FLT. The batwing has an HD cassette radio; that's what makes me think it's an early 90's? I guess my main question is does the cable get routed between the trees, or go outside (forward of) and then under the lower tree? Can anyone with a similar FLH fairing just look up between the forks at the lower tree and tell? It wouldn't involve opening your fairing.
Attached Thumbnails clutch cable routing-1980-flt-left.jpg   clutch cable routing-80-key.jpg   clutch cable routing-80-dash-1.jpg
Old 09-07-2014, 04:10 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
If it's a 1980 and the engine is rubber mounted, it's an FLT. The FLH was still a solid mount. 1983 was the first rubber mount Electra Glide (Batwing) FLHT.
Old 09-07-2014, 05:21 PM
SeaZund's Avatar
SeaZund
SeaZund is offline
It IS a 80 FLT that the PO converted to a 90's FLH batwing. My question is how should the cable exit out from under the present batwing fairing?
Quick Reply: clutch cable routing
