Ignition Woes...
Make sure we're the voltage regulator mounts to the frame has a GOOD ground. No paint, no powder coat.
Harley voltage regulators shunt excessive voltage to the frame.
https://www.electricity-magnetism.or...age-regulator/
The is no such thing as shunting to the frame.. That is a single point.. Shunting requires 2 points.. What they do is shunt the output of the regulator.
The examples in that link are not what HD does. For one using a linear device dumps all the excess energy. This create an excessive amount of heat. Early English and Japanese bikes got away with it as they had marginal charing systems. Not a whole lot of power / current generated..
I believe that HD regulators use SCRs or Diacs to chop the output of the regulator.. @bustert has the schematics that are close.. The alternator is like a current source. Shorting the output dumps less power then trying to regulate it with a linear device and reference or Zener diode.
I've not seen regulators spike but I've seen them go high after some heat.. I would expect that loose component inside the device could cause spike tho.
I just skimmed through this quickly, so I'm sorry if I missed something, but I had a similar problem with an idiot shop on the road working on my FXRS. They had a Dyna ignition which required a 5 ohm coil instead of the usual 3 ohm for most Evo Big Twins. There were many other problems with their work, but when I got them sorted out at my home shop the bike ran fine for a short time and then just started backfiring and eventually would only run for a short time before it had to cool down before it would run again. They had sold me a new 3 ohm coil instead of the required 5 ohm. Just make sure you have the right coil.
t150vej (04-26-2024)
mp, I know from another thread several months ago that he has a 3 ohm coil and it's an S&S - he posted a photo of it.
But that's good you brought it up because he's been thru many ignitions in a fairly short time and the only constant is the S&S coil.
Hotrod, easy as it is to change on that softail, why not put a stock coil on an run it on dual for for a while, see if the single fire coil is acting up.
Trumpet (05-04-2024)
