92 FXR rear brake assembly
Old 08-19-2014, 11:19 PM
ssmith579's Avatar
ssmith579
ssmith579 is offline
Default 92 FXR rear brake assembly
Does anyone have a picture or diagram of how the rear brake calipers on an FXR are put together? My brake pads were very loose in the caliper and when I took it off this spring wire was in there. I can't figure out where it goes.
Old 08-19-2014, 11:30 PM
apples402's Avatar
apples402
apples402 is offline
there are two holes on the inner side of the caliper bracket assembly, it goes in the two holes, then over the outer pad( the one on the piston side)
Old 08-20-2014, 05:29 PM
ssmith579's Avatar
ssmith579
Thanks! Got it figured out. works much better when it's installed correctly.
Old 08-20-2014, 06:39 PM
apples402's Avatar
apples402
good deal...glad it worked out for you.
Old 08-21-2014, 06:11 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Wink
I'm not sure that they will answer that particular question, but there are on-line parts websites with exploded diagrams for your bike, which I routinely use. I prefer this one.
Hundskrüppel
02-06-2018 01:41 PM
Ipara
03-31-2016 01:14 PM
01fxdxt
Evo Era Parts
08-12-2015 05:23 PM
punkroxxx
Evo Era Parts
01-11-2015 09:36 PM
dirtbag1
EVO
10-22-2013 09:41 AM
Quick Reply: 92 FXR rear brake assembly
