Exhaust flange fit
Exhaust flange fit
Anyone have issues with their flanges not fitting? I wacked my exhaust system during a sharp right turn and started to smell exhaust fumes. I figured I cracked the pipe on the underside so wanted to take a look at it. I went to remove my system (a shop installed Patriot 2 into 1) and had a real difficult time getting it off. I suspected that the exhaust studs may Have been bent, so removed them. Sure enough two were bent. Ordered some new ones. They went in nice and straight. The studs are bottomed out. I went to put on my exhaust (I did crack it and had it welded up), but found that even with new studs the flanges don't want to fit. The bottom portion hit my top cylinder fins. A shop installed the exhaust system. Could they have used the incorrect flange and just jammed them in? Do they make different size flanges?
Jack Straw
02-27-2017 10:18 AM
