Just installed Power Duals on 09 fltrse3. I have an exhaust leak at crosspipe/header joint. Torca clamp seems pretty tight. Still has room to go further just not sure if I should tighten more. Don't want to damage anything. Anyone experience this and how did you fix it.
Thanks for the reply. Spoke with V & H they said it should only need to be tight enough to prevent movement of crosspipe to seal. I will have to double check it.
