Sponsored by: Jekill and Hyde
Internal Exhaust Coating
Old 11-29-2015, 01:26 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,813 Likes on 1,065 Posts
Originally Posted by shimaze
What color is this paint? From your pic, it looks blue. Did you use it on the outside? If not, what is your opinion on using it on the outside? I am thinking of using it on the inside, outside, and on the back of heat shield? I will carefully tape off the front chrome part of the heat shield before I start painting. I have several caps that I can install on the can to make it spray like a normal can of spray paint.
OldEnuf2NoBtr, I am really gonna !@#$ it up!
All I can say is, "If it looks too good to be true then it probably is." If this was such an outstanding product, with certified results, then everybody from all the manufacturers to shade tree mechanics would be using it as it has been on the market for many many years. An actual ceramic coating is a proven heat reducer and comes with an almost indestructible finish where as this product would be a crap-shoot at best. Good luck if you decide to go ahead and try it.
Old 01-18-2017, 01:26 PM
Houston_t's Avatar
Houston_t
Houston_t is offline
Any updates on this ?
Old 01-19-2017, 11:15 AM
DanDman's Avatar
DanDman
DanDman is offline
I only had it for a few months, was holding up fine. The small area the pipes were welded looked the same, no flaking inside.
I went with Jet Hot silver coating inside and outside the pipes mainly for appearance. I was at a local powder coater and he had some coated bus exhaust pipes ready to deliver. They looked so nice that I got mine done. They look like polished aluminum, I paid about $150.00.
I would use the Eastwood product again.
skinless
02-20-2014 12:04 PM
toastman
12-13-2012 08:51 PM
sickboy75
07-24-2012 01:56 PM
TRAVIS174
07-09-2009 06:04 PM
FXSTCHEWY
03-16-2008 10:06 AM
Quick Reply: Internal Exhaust Coating
