Revert to stock exhaust
Stefan Neufeld (01-13-2017)
Stefan Neufeld (01-14-2017)
It will run fine if it runs fine now. My 04 had open duel Pythons on it. The Harley ECM was mapped to adjust since it is closed loop with no oxygen sensors. I put a brand new takeoffs from a 96 CI Night train. It runs fine. You cannot even really tell any difference in the plugs. The Harley set is from the open exhaust. Both set have 10 K on them. The rusted ones are from a freak ice storm I got caught in down South and they thru salt and sand all over everything. Bottom end is way better since the Pythons did not have a cross over and engine braking sucked. I never run top end and all that noise sucked.
Kind of at a loss somewhat because it seems uncommon to go back to the stock(ish) tune. If you were only running pipes, it may not even be tuned at all really. I'm not saying it isn't, just that sometimes guys throw slip ons on and don't get a tune. Even if it was, it is just richened up a little bit all across the fuel maps, which isn't really going to hurt anything. It might soot up your pipes a little tiny bit. That's about it. Put some miles on with the stock pipes and check your fuel mileage and it will tell you if your in the ballpark of where you should be.
Stefan Neufeld (01-24-2017)
If your bike has a dealer-installed stage 1 tune another dealer should be able to undo it. There is probably no added tuning device.
