Fishtail baffles
Fishtail baffles
I have fishtail pipes on my bike with no baffles in them. I just ordered some baffles and the way they are supposed to mount will not work because the mount is supposed to be toward the rear of the bike and there is no access.
Can I mount them backwards or any ideas to mount them the correct direction?
Are baffles slip in
do the baffles fit inside pipe looks as you could install at spot where you tips clamp what length are they also do not need a lot around 4" should be sufficient Don't want to put to much back pressure on motor. Luck. Wild Bill
mine are one piece but have baffles built in there down about 12" from tips
