questions about the '09 96" motor
Hey all, I have been reading countless threads about crankshaft runout issues affecting the '07 and '08 motors. As far as I can tell it is NOT build date specific and is more to do with tolerances during assembly and that the crankshaft is not up to the job and a lot of people are putting the S&S crankshaft in to solve the issue.
My question is, have HD made any changes from '08 to '09 to address this problem. Seems to me like waaaay to many people having motors worked on or replaced.
Thanks.
Thanks.
Not hard, just finished a 103 motor with roller bearings. If converting to timken its a little tougher. Just more work.
And as for the cranks, i dont think i would call it an empidemic, but something to look out for when opening a cam chest. I have measured about a dozen or so this year and so far only 2 failed. It also depends on what you call a bad crank. Dealer say .012, i wont even think about anything over .006 or so, you will just have problems.
Thanks.
Thanks.
Cranks scissoring is not unheard of but not something I would be concerned about on a stock bike, or one built to 103/107 for that matter. It is an issue , but not one of epidemic proportions.
As others have said, if you open up the cam chest, take a runout reading and if in the .000 to .003 range you are golden, higher than that even may be alright but then becomes something to watch as the miles add up. I would not open up the camchest just to take the runout readings unless there was a reason tosuch as bad vibration, loss of oil pressure, etc.
It is not worth the added expense to split cases and have crankwork done unless you are getting into the areas of 125+tq IMO. I do know of some 113 and 117 engines running around with stock cranks without issues to this point. How they will hold up long term is an unanswered question.
Ron
.... I would not open up the camchest just to take the runout readings unless there was a reason tosuch as bad vibration, loss of oil pressure, etc.
It is not worth the added expense to split cases and have crankwork done unless you are getting into the areas of 125+tq IMO......
I dont know the cost of the above suggestion, but surely it would be cheaper than major engine repairs due to scissored crankshaft 6 mnonths after the warranty period?
Thanks for your advice.
Yeah, I am with you on that one, I feel your pain.
I really see no rason for someone to tear into an engine to check runout unles there is something telling you that you should. Ron has vibration and has for some time, therefore he went in and checked and found excesive runout.
If it runs good, does shake the fillings out of your back teeth and has good oil pressure, in all likelihood, everything is fine. The cranks are a weak point but are they failing in huge numbers, no. But also guys that only ride 5k a year or a lot less may ride for many years prior to having a problem. Kinda like the cam chain tensioners in pre 06 bikes, some wore out at 25k, some at 50 k and some still going strong at almost 100k. No rhyme or reason, just is.
