Sponsored by: Jekill and Hyde
Do I need roller rockers for my build?
Old 10-07-2009, 08:04 PM
producer's Avatar
producer
producer is offline
Smile Do I need roller rockers for my build?
Hi everyone,
" Do I need roller rockers for my build? "
I recently had to rebuild my build, if you catch my drift. The mistakes were made by me, just to clear the air. Any way this is what I've got.
1) 95" twin cam
2) 10.4:1 compression
3) ported heads with over 180+ PSI valve seat spring pressure. 1.90" intake valve/ 1.63" exhaust
4) cams .580/.530 lift.
5) stock lifters
If anything else is relevent to this question, please let me know. I'm kind of an idiot.
thanks
Old 10-07-2009, 08:15 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
Default rockers
roller rockers are easier on the valve train,but for the lift your running you dont need them,but they wouldt hurt anything either(really would be no noticable hp gain)
kirby
vee twin racing
Old 10-07-2009, 08:28 PM
producer's Avatar
producer
producer is offline
Kirby,
thanks. I'm mostly looking for engine top end life. Since I rebuilt, I haven't put the lid on the top end and wanted to wait and ask some questions before I just put the stock rockers back on. The stock rockers have 30,000 miles on them. might be a good time to upgrade now.
Old 10-07-2009, 10:24 PM
beaureed445's Avatar
beaureed445
beaureed445 is offline
I would. Personally, I'd run rollers on anything over about .575 lift, so you're right on the fence. Since you haven't buttoned up the top end yet, it probably wouldn't hurt to go ahead and do it (other than spending the $$$).
Old 10-07-2009, 10:40 PM
PhilM's Avatar
PhilM
PhilM is offline
I ran stock rockers with my HQ-0039's w/o any issues whatsoever. Ask Doug what he recommends with that cam.... "Stock is just fine, but if you wanna spend $$, he'll sell ya some".
I'd use stock... wait ~ I did!
Not necessary.
Old 10-08-2009, 06:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Food for thought, is that Harley now offers 1.725 non-rollers for on the cheap. I believe they are under 200.00.
Those will make your engine think that you changed the cam, and if the OE hammers have shown good service for the past 30,000, give 'em a whirl.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 10-08-2009, 08:10 AM
prodrag1320
Default 1.7
if you go with the 1.7`s,make sure you double check your valve to valve & valve to piston clearances,both will increase.measure your tappet lift and muliply by 1.7(that will give you actual cam lift)
kirby
vee twin racing
Old 10-08-2009, 09:32 AM
producer's Avatar
producer
producer is offline
kirby
vee twin racing
Kirby,
I don't understand all that ratio stuff and how it effects the actual lift on the valve end. I won't have any issues with the valve/piston clearance. I won't have issues with the valve/valve clearance either. I've checked that. I know that my motor is breathing very well already from the last build at 1.625 ratio. Am I really going to gain all that much going to 1.7?
PS...my brother is sending me some stock rockers with 9000 miles on them on Friday. I'm going to inspect them and compare them to my 30,000 mile rockers.
I'm still considering the rollers though.
Old 10-08-2009, 11:41 AM
Dalton's Avatar
Dalton
Dalton is offline
Rollers are overkill for anything less than .600 lift IMO.
Running the HQ 575 with stock rockers for 35k miles now without issues .
Old 10-08-2009, 12:30 PM
producer's Avatar
producer
producer is offline
Everyone,
I've made up my mind and thanks everyone for your input. I'm saving my money and staying with the stock rockers.
E.
Quick Reply: Do I need roller rockers for my build?
