Sponsored by: Jekill and Hyde
Removing old gas
Old 03-11-2010, 09:48 AM
Hardly Dangerous's Avatar
Hardly Dangerous
Hardly Dangerous is offline
Default Removing old gas
Not sure if this is the best place to post this but I think I have stale gas in my tank. It has been sitting for almost 4 months over the winter and the bike doesn't start now. It is an 06 Streetglide. A few questions. What is the best way to purge the system of this gas? Can I just drain the tank and add new fuel? I have a manual but it really doesn't explain the best way to drain the tank or fuel system. If I just need to drain the tank do I need to depressurize the system?
Old 03-11-2010, 10:34 AM
FLYING's Avatar
FLYING
FLYING is offline
Gas will not turn bad in only 4 months perhaps you have have another problem however,if you want to remove the fuel from the tank I would suggest disconecting the battery first and the easy way would be to siphon it out.Just take a hose ,put it in the tank then using a air compressor and a blow gun put the blow gun nozzle in the tank with a rag wrapped around it to help seal it and give it a shot of air this should start the fuel comming out of the hose.If it quits just repeat until the tank is empty.
Old 03-11-2010, 10:39 AM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
I think you have another problem. Unless you put old gas in there in the first place, I cant see 4 month old gas going so bad to the point where it wont start your bike. How is the battery?
Old 03-11-2010, 01:25 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
I have had gas sit in generators from Huricane to Huricane, year to year, and it still works.
I know now a good idea but there it is.
GREENOHAWK69
EVO
02-21-2023 02:43 PM
Lobo45
01-11-2015 05:35 PM
Great Gazoo
11
09-05-2010 01:46 PM
ulloaron
03-11-2008 11:28 AM
wild wally
11-19-2005 10:41 AM
Quick Reply: Removing old gas
