"hopping up"
"hopping up"
How irresistible it is to hop-up our motors! No matter how much power it already has, or our ability to handle that much power, we always want MORE! And it's so compelling and so much fun that we even enjoy hopping-up OTHER people's bikes.
When we first get a bike perhaps very few of us really know the extent of all the customizing we are about to undertake; some might actually feel no need to ever change a thing. But doesn't it seem safe to say that virtually none of us has a well-thought-out plan to start with? Maybe one is not possible. Our first impulse is to increase horsepower and torque--probably w/ little thought to improve tires, handling, braking, riding skills...; I'm no different. ;-)
Oh, most of us have a vague idea that a motor (engine) is an air-pump, and that, to get more performance, we must improve its' breathing.
We are usually advised to begin w/ an air-cleaner and performance exhaust; presumably most stock ones have not been optimized for maximum performance. And this improvement is one which (someone will correct me if I'm wrong):
a) is generally affordable.
b) probably won't void the warranty.
c) will often provide a more or less noticeable improvement, by itself, even if nothing else is planned.
d) is needed in order to get the most out of any other subsequent improvements, such as cams, bigger carb/valves, porting, higher compression...
My '09 Super Glide Custom has only 6600 miles, so I do not yet wish to make internal engine changes. A Venice, California bike, the stock exhaust cries out to be replaced.
Would an exhaust off an '08 Screaming Eagle be a good choice for performance and one which is not overly loud? Would it fit? Which exhaust would be significantly better?
Other options for this 96-inch motor?
All comments welcome.
lo-rider
lo-rider
Cycle Shack slip-on's.
About $175.00 most anywhere.
Damn good mufflers.
Scott
Damn good mufflers.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
slip-ons
Scott,
thank you for your suggestion. I see that the Cycle shack slip-ons are very popular. However I just bought a set of Rush slip-ons from another forum member; these also have a bunch of fans on this forum. Here's hoping.
When I bought the bike (last week) the original owner also gave me an SE Pro Tuner for it. Now I'm wondering if a replacement air cleaner would make any noticeable improvement w/o losing low-end torque.
lo-rider
lo-rider
when it comes to the dyna family these bikes are allready lighter then touring bikes or sport touring bikes such as street glides,all i did to my 06 dyna was a power coommander and a high flow air cleaner,and this woke the bike up enough for me that there is no way i would even consider any type of build on this bike its light and nimble and has all the power i need to kill myself with as is.oh i did put on bassoni pro streets slash cuts also more air,more fuel and a less restricted exhaust is all that most harleys need to perform well!!!!!!!
Scott,
lo-rider
lo-rider
neither will cost you too much low-end torque...
a/c
Thanks for that; I have seen impressive claims of which I am naturally skeptical. Nevertheless I accept that some perform better than others, and that it can be a noticeable difference. Preferably, I would have one which uses the stock cover. And I have observed that some (Big Sucker...?) may be inadequate in controlling breather oil.
Does someone know if any of these after-market air-cleaners are street-legal in California? The SE perhaps? Others? Is that an important consideration that we (who live in Calif.) should be aware of?
lo-rider
lo-rider
