Most hp out of a 96" twin cam ?
I was wanting to get the most horsepower out of 09 96" Street Glide and was thinking about getting some headwork and a cam and a good tune. Whats the best cams and head combo for the most torque ? How much power can you get out of a 96" motor without boring it out. Does screaming eagle makes heads that i can bolt on instead of sending mine off and get ported and polished? One more question, I just have rush slip ons and i hear all this talk on the power the thunderheader gets. Would it be worth the $600 to drop my rush slip ons and get the thunderheader?
Thanks
Thanks
baisley heads
t-man 525 cam
tts tuner
you will see over 105/105 you have to not get into the numbers game as if the mark is not met customers are un happy.
but that combo i mentioned will acheive that with no problem
yes the t-header is good but the fat cat is better
altho with the combo i just mentioned a set of slip and stock head wpie
call Dave at JD,s cycle works 1-610-297-0321 he has done a dozonsor so of these builds with stock cylinders and pistons just head work and cam plus tune
t-man 525 cam
tts tuner
Thanks
Thanks
Mucho power everywhere.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Im debating on wether to do the 103" bb kit or put that toward sending my stock heads of and get them ported and polished. I think having ported and polished heads would give me better hp and less heat then just the 103" with stock heads. About how much does it cost to get my heads ported and polished by a good professional?
A BigBoyz 'street port' job is $299 but there is an additional charge for decking, if required, to achieve you desired compression and for the cost of larger valves, which, IMHO, you don't need. From there, the next jump is to somewhere between $600 and $1000, depending on what you want.
