Slight misfire at idle and low cruising speeds
1994 1200 Sporty that has a misfire that I am trying to fix. Took the air cleaner off to change out fuel lines (old ones needed replaced) figured I would start the bike make sure it was leaking and noticed air/mist was popping out of the carb where the filter would go on.
Changed out plugs and cleaned carb but not sure what can be the problem. Maybe just a rebuild kit...? Runs fine when you rev it up and during acceleration but when i let off and come back to a steady throttle it has like a slight hesitation and kinda makes a pop sound where the air filter is. Any thoughts?
