Could be, are you still running just the basic Stage 1 ECM download from Harley? If so I would have it tuned. With those cams also it may be a bit lean causing extra heat in the combustion chambers. A good tune can do wonders.
wow... 30Deg here today... move to Canada, ill swap with you to AZ...
had same issue with my 2011 SG..was random last season.. I made my PV map a little ritcher in the zone where it was pinging and did go away.. need to see what happens this year if it ever gets warm here...
