What does having Screaming Eagle pipes mean
I recently purchased a 2007 Electra Glide Ultra and have a question about it. It has Scream Eagle pipes on it so does that mean anything about performance? I do know it's not the CVO model. In other words can you just put the pipes on and that's it or do you have to tune the engine to the pipes? Just curious is all, the bike runs just fine.
screamin eagles are performance parts. they make parts for performance upgrades including exhaust.
usually u have to tune the bike if you put screamin eagles on. i had screamin eagle intake and exhaust installed on my sequential port injected 05 fatboy along with a tune. it may run lean without a tune. if the previous owner already had the tune done then u shouldnt have any problems
Or is the cover a dead give away
if you're refering to the oval shaped chrome cover that goes over the air filter, then no, the cover alone wont tell you if you have a stock or hi flow.
you can have a SE or big sucker and still use the stock chrome cover. so you need to remove the chrome cover and see if you have an after market filter underneath it.
Take the chrome oval "football" cover off with a properly sized allen wrench. If you don't own an allen wrench, stop, find a good independent "indy" mechanic and go there. If you do have a set of allen wrenches, remove cover. If the air filter looks like white corrugated paper and is roughly oval shaped, its the original air cleaner. If it is round, it is a high volume air cleaner.
