Sponsored by: Jekill and Hyde
Acceptable CVO 110 piston clearance
Old 10-04-2012, 07:54 PM
panheadsteve49's Avatar
panheadsteve49
panheadsteve49 is offline
Stage II
Default Acceptable CVO 110 piston clearance
About to start a modified CVO 110 build on a 04 RK. I am using stock HD (Mahle) pistons and stock HD cylinders that were supplied in the 110 upgrade kit. Mahle's website recommends .001" piston to wall clearance measured at 10mm from bottom of skirt. I had an independent tech to torqueplate and check this clearance for me and they are as follows: Both pistons measured exactly the same. However one cyl measured for .001-.0014 clearance and the other cyl measured for .001 -.0018 clearance. Difference was in taper, not out of round. My tech said he would run them, putting the cyl with more clearance on the rear as it tends to to run hotter.That makes sense to me. Is this additional piston clearance and cyl taper enough to cause piston noise, pre-mature wear, oil consumption etc? (preferrably looking for imput from techs who have actually checked these factory CVO 110 clearances prior to install as well as opinions which is all my tech can provide me)
Old 10-07-2012, 09:49 PM
panheadsteve49
Stage II
Default Acceptable CVO 110 piston clearance (repost)
liquidr1
08-29-2016 06:01 PM
plongson
2014-2023 Touring Models
17
07-05-2015 07:00 PM
Iron lHorse
01-12-2014 07:57 PM
whetsel.m
04-28-2009 12:45 PM
Bumbobee
11-02-2008 04:24 PM
Quick Reply: Acceptable CVO 110 piston clearance
