opinons on my 103 build
ok guys I am wanting to build the 103 in my 2013 wide glide. It currently has the mods in my signature. Here is the list of parts I am looking at let me know what you think of the combination. Any suggestions are welcome as this is my first 103 build. I want to stick with the 103 and not do a 107.
22144-08B SE Pro Twin Cam High Compression Forged Piston Kit 3-7/8 Bore
TW-555 cams
Head Work - Looking for suggestions
Fuel Moto Pushrods
Woods Directional Lifters
27639-07A SE Pro High Flow 58mm EFI Throttle Body
29667-07 - SE Pro High-Flow Intake Manifold For 58mm Throttle Body
27400002-SE Pro High-Flow Injector Kit
37000121 SE Variable Pressure Clutch
TW-555 cams
Fuel Moto Pushrods
fuel moto push rods are made by smith brothers they make quality parts. if there were so many problems with adjustable pushrods no body would use them, if they are install correctly using locktite they should not come loose. and with higher lift cams verses stock its nice to have the ability to adjust more preload on lifters to keep the valve train noise minimal.
103 build
maybe have your current throttle body polished and worked reason is to the best of my knowledge i may be wrong. you need a new manifold for the 58mm TB i think you will also limit your options for air cleaners.
no reason to spend so much on a manifold and throttle body, for the hp increases of just a few HP maxium. the $ to HP raito isnt very good. can have your current throttle body done for around $275, maybe throw in some high flow injectors.
but i would run your build by fuel moto if your buying parts from them, they are real engine builders i think fuel moto may suggest adjustable push rods also. i used adjustable pushrods for 40,000 miles on a 103 with 108 hp 109 tq never had any trouble
