cam questions
cam questions
so heres the deal guys. this spring i installed a set of se204 cams in my tc96 softail. and i love them. but like a lot of speed junkies i want more and want to go to a 103. here is my question. a lot of people say that the 10:1 compression of the se kit is to high for the 204 cams. however i did the math with the big boyz calculator and the ccp and corrected compression is higher with the 255 cams which is what stage 2 103 kit comes with.
so why would the 255 cams work but not the 204's?
to lower compression ive looked at the keith black dished 103 pistons. makes it about 9.5:1 compression. anybody ever used those?
10-10.25 is good for 204s in 103. Do not go below 10-1! If ya go with the SE 10-1 pistons go to thinner head gasket for a little more compression. Might think about high ratio rockers also for some more lift. 10-1 with 225s does cause problems...
........or bore to 107", using a .040" head gasket and install a set of S&S .570's.
You'll never wonder if you did it wrong.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
The KB piston is a hypereutectic piston, so is the H-D OEM piston. I have never used them so I have no personal experience with them but lots are in use with no issues.
Then there is always Scott's option which is a good one as well; the 570 cams are great. Those cams in a 95" motor with decent heads will make 100TQ/100HP every time and very useable power. In either case, the tune will make the difference.
Common mistake...
https://www.hdforums.com/forum/touri...ited-dyno.html
Decide for yourself.
