Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Sight glass on brake fluid reservoir...
Old 10-21-2015, 12:31 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Default Sight glass on brake fluid reservoir...
What does it do? I've had my Ultra for nine years, change brake fluid every two years, and every time I wonder about the sight glass in the covers of both front and rear reservoirs. I have yet to see anything in it.
I'm thinking that perhaps if you didn't change your fluid, and it darkens over time, that you may see that in the sight glass, whereas you don't see clear, fresh DOT 4 brake fluid.
Old 10-22-2015, 07:08 PM
MNPGRider's Avatar
MNPGRider
Well, either I asked a really dumb question, or no one else knows the answer either. When you remove the reservoir cover, you can see the sight glass telescopes down into the fluid. Does something happen, perhaps, if the reservoir is low on fluid? I'm really wondering what this sight glass is for.....
Anyone?
Old 10-22-2015, 07:11 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
In the correct light, (from overhead) if the fluid drops below that plastic pointed pintle sticking down from the underside of the cover, the button will go from dark to light.
Remove the two screws and raise up the cover. You will understand.
Old 10-22-2015, 07:54 PM
MNPGRider's Avatar
MNPGRider
Thank you, ripsaw, if that is what happens. In other words, if you have a fluid leak, you will see it in the sight glass?
Incidently, I do have the service manual, and can't find any reference to it at all.
Old 10-23-2015, 04:39 AM
Jackie Paper
If you totally ignore maintenance, as the pads go from new to almost warn out, the pistons in the calipers will get far enough out that the button will show a low level also. I would think the indicator would be mentioned in the owners manual.
Service and my State inspection removes the cover to check.
rwt
06-22-2017 06:58 PM
jeffrob07
EVO
25
06-05-2017 07:36 PM
lenny
04-17-2010 06:35 AM
NYSportster
Wheels/Tires
33
02-14-2009 09:39 AM
vet767
10-26-2008 07:20 PM
Quick Reply: Sight glass on brake fluid reservoir...
