ABS performance worse than standard brakes?
I've been thinking of trading my '02 FLHTCUI for a later model ('09 - '13) with ABS. A good friend told me that he has just disconnected his ABS because it made braking worse - longer to stop under heavy braking. I forget what year his is - one of the early years of ABS.
Anybody have any thoughts one way or the other?
Received 1,934 Likes
The efficacy of ABS brakes has remained a talking point for, some, since the day they were first introduced to the automotive industry decades ago.
The issue, in the main, is a settled one but should you decide to do more than keep a weakening narrative alive, your solution is simple. Disconnect your ABS brakes like your "friend" did. Your insurance company will probably be delighted by your decision to disable your ABS brakes.
I have read that the early H-D ABS system left a lot to be desired in several ways, one being that it kicked in too early. I have never heard of anyone claim it lengthened braking distance and really do question that. Just doesn't stack up, unless there was something wrong with that bike.
I'm no fan of ABS on a bike, having done 50k with it. In reality most of us can actually brake much harder in all conditions than we think we can, so for many riders ABS is simply a placebo. To activate ABS in perfect conditions will probably require some pretty serious braking input, but I don't accept it will take longer to stop.
If that's keeping a weakening narrative alive, so be it.
I have an 08 with ABS. The software is current. I will tell you that in normal braking situations when encountering bumps or any type of situation where there is traction interrupted by a tire not in contact/brief no traction with the road, buckled pavement , wet painted lines etc, and then there is good pavement again, the abs WILL kick in and dump brake pressure. The problem is the system is super slow to rebuild line pressure again and stopping distance will be increased due to this. Its a pretty archaic acting abs and takes what seems forever to let the brakes go back to working in these situations. The bike will stop faster the the rider lets off the brake and gets back on it himself as the system is slower to react than the rider. As far as guys just stomping on the brakes with no regard to road conditions in a panic situation , yeah the abs is way better than an panicked rider in that situation. Its not a cut and dried thing. I think if a guy rides more aggressive he will hate the abs, if he tends to ride more passive then he may like it.
I'm not a fan of ABS either. I've had multiple sportbikes, a supermoto & now added a Low Rider S to my stable of currently 3 bikes & only the Harley has ABS. Once I figure out how to bypass it'll get accomplished.
On my daily truck it was as easy as pulling the ABS fuse. For those that think I'm crazy I'd be happy to give you a ride. With the suspension & 37" tires the weight of rolling stock causes the ABS to kick in before it should & the braking distance exponentially multiplies; without ABS line pressure increased & braking distances shortened dramatically.
qtrracerqtrracer is offline
__________________
107" 11.5-1 comp, 9f's, Boarzilla, Grasser Heads and T/B, Ohlins, True Track, Galfer Full Floating Wave Rotors, 1.26hp/ci
Perfect explanation of what happens on my 08 as well. Just replaced the control module due to failure, with the latest and greatest. Still happens.
__________________
