Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
160/60-16 rear tire for an ultra classic
Old 10-21-2008, 07:30 AM
Beau Long's Avatar
Beau Long
Beau Long is offline
Stage IV
Default 160/60-16 rear tire for an ultra classic
Is it possible to put a 160/60 rear tire on an ultra classic?
Old 10-21-2008, 09:44 AM
Prog Rocker's Avatar
Prog Rocker
Prog Rocker is offline
Exclamation
I assume you meant a 160/80B16?
If you did, then not likely.
I don't think that a 160/80B16 would fit on a stock Harley rim...and even if it did, or you got a rim that would fit it, you would probably not have enough clearance without other modifications to your bike, like the brake stayarm, the exhaust mounts, etc.
Do not...I repeat...DO NOT try a 150/80B16...!!! Even though it should fit on a stock Harley rim, it doesn't have sufficient load capacity to be safe to use with a fully-loaded Ultra.
Ride safe!
Cheers
Old 10-21-2008, 08:08 PM
Beau Long's Avatar
Beau Long
Stage IV
Default 160/80b16
It actually has a 932lb load capacity according to Dunlop's sight.
Old 10-22-2008, 08:05 AM
Prog Rocker
Exclamation
Yeah, but I was trying to steer everyone clear of using a 150mm instead...! Using the Load information you mentioned, here is why...
The 160mm tire has a Load Index of 80, meaning it can hold up to 932 lbs. of gross weight at maximum PSI.
However, the 150mm tire has a Load Index of 71, meaning it can hold up to 761 lbs. of gross weight at maximum PSI.
That would mean, that even at maximum inflation, you will have compromised the weight allowance by 171 lbs.! Such a tire mounted on an Ultra-Classic would be instantly overloaded. If it was also just a bit under-inflated, then there is a big problem...!
Ride Safe!
Cheers
Old 10-23-2008, 08:07 AM
HB's Avatar
HB
HB is offline
Isn't the 402 mu85b16 the same as 150/80-16
Old 10-24-2008, 08:36 AM
Prog Rocker
Exclamation
Nope.
An alpha-numeric MU85B16 rear tire is very similar to a 140/90B16, and as such their load ratings are also very similar, but not a 150. Not even close!
Cheers
Old 10-24-2008, 06:35 PM
HB's Avatar
HB
HB is offline
Check out the different ratings. I know there is a lot of talk about the E 3's on the big touring bikes. I am seriously considering them on mine next time around.
raksasas
10-08-2017 02:12 AM
GS1000S
06-01-2014 07:25 PM
Essentialbill
03-09-2014 10:52 AM
dw2169
04-09-2008 10:19 AM
rogerm
09-07-2005 07:26 PM
Quick Reply: 160/60-16 rear tire for an ultra classic
