Will '09 rear touring shocks fit on 07 SG?
Thanks for the tip. Rode two up on a recent road trip and the rear shocks (Progressive 440s) had a tendency to bottom out on medium sized bumps. To eliminate that, I want to replace the 12" shocks with 13" shocks for the extra travel. Guess I'll pass on the '09 shocks and look for '06-'08 shocks.
The Street Glide & RK Custom has 12" shocks. They are valved and sprung harsher due to the reduced travel.
There are more than enough posts on the Progressive shocks here on this forum. Unfortunately you were one of the members who discovered these shortcomings after you bought them. Not all shocks are the same so don't give up. I am going to post what is inside of an air shock as I have cut one apart for demo & taken photos. Good luck with them.
Once I pick up a set of 13" shocks off of e-bay, I'll bolt them on and see if there's any improvement. If yes, then the 440s are going on e-bay for sale.
Plow64 you did the exact same thing I did with my 09 FLHX. Except I used 07 FLHTCU Stock shocks and lowering cams on my SG. YES the ride is 100 time softer. That shock give you more travel hence a better ride. Only problem now is that I have a brand new set of Progressive 440 to sell also!! Good luck!!
Google motorcycle lowering cams, there are numerous companys out there selling them now. I have even seen them in some of the motorcycle mags. If you still cannot find them e-mail me at edge2edge@comcast.net and I will look for my receipt and help you with the search. Bill
