An easier way to adjust a Springer?
Just wanted check with some of the Harley techs or Springer gurus out there that are members of this forum to see if there is an easier way to adjust the Springer frontend both the neck and the rocker bearings. In the service manual you have to nearly take the whole front end(fender, wheel, caliper, and everything else) apart to adjust the rocker bearings. The Fall away for the springer you have to remove the hand controls and minimize the weight from the front end to get an accurate Fall away measurement. I just wanted to know if there are any shortcuts or tech tips on doing a quick and accurate measurement for the fall away and if you can just torque the front end to a certain spec without removing everything from the frontend for the Rocker bearing adjustments. I am new to Springers but I love the look. How serious is it if the Rocker bearings aren't adjusted? Have there been alot of problems with the Rocker bearings going bad? I want to do the maintenance on the Springer right, but if there are easier ways of doing it that would be great. No need to re-invent the wheel when others have been there and done that. Thanks.
RE: An easier way to adjust a Springer?
Springers are a hoot and very easy to work on.....
The manual is actually pretty accurate in getting the proper feel and "Rock and Roll" for the road .....
A properly dialed in set of rockers will allow the bike to "Float" on the road surface.......
As far as the Fall-Away... I will always go on the tight side (2 inches), to prevent a tank slapper as well as a firmer feel in cornering.....
To do the "Proper" servicing, You will need to invest in a few special tools (1/2 allen bit, 1 1/2 crowsfoot, inch lb torque wrench-dial, hand made star-wheel adjuster tool, plumb bob to name a few...)
Thanks Shovelhead Bob. I was hoping that you would reply to this one. So Stay with what the Service manual says? Now I know what the torque wrench and plum bob are for but what is the crows foot and the starwheel adjuster used for? I know what a crows foot and star wheel adjuster are, but not sure where on the bike you would use them. Are you using the Crows Foot in place of the special tool use for the neck adjustment? I know in the service manual it list a special tool for the Fall away adjustment but I don't have my manual with me at the moment, so I am not sure if the Rocker Bearing adjustment says to use a special tool or not. Thanks.
Sounds like a lot of fun. Thank you for your help. It sounds like you really like working on Springers. That must be why people say that they look good but are a pain in the a$$ when you have to work on them. Well I guess I will stick with the tried and true service manual and do my best not to F#@K anything up.[8D]
