Panhead motor doesn't fit in frame
Hey Guys I am hoping someone can help, I have a 1965 Panhead motor and tranny that I tried to put in a swingarm frame that was given to me with the bike as it wasn't in its original frame, I was told this was a 65 repro frame so of course I had it powdercoated and started the change over and come to find out the motor will not fit, the rear head is very tight against the top frame and the down tube. I am thinking maybe I have a 64 frame but unsure because this fame is a reproduction and no stampings, was there different swingarms for 64 and 65 or do I have a 66 or newer repro? just wondering if there are alot of variations and what my best options are as I know an original 65 swingarm frame may be hard to come by.
thankyou
VP
thankyou
VP
thanks
VP
OK so you are saying the rear cylinder rocker pan is hitting the top of the seat post where it meets the frame backbone. I just looked online and there are 2 replacement frames for 64-65 FLH. To my knowledge the only difference was electric start. So that said, Is your inner primary for electric start and can you mount the motor in the frame without the inner primary? I guess I am looking for is it possible to put your powder coated frame together as a kick only 1964 assuming you have a 64 frame and the 64 64 panhead cases are the same.
With the bottom end case tab sitting on top of the frame tab at the seat post, can you get 2 bolts in the frame? Is your top motor mount forcing the back pan against the frame? Have you tried to ignore the top mount and attach the inner primary and connect to the transmission? Is it possible the top mount front to rear bracket is not correct?
I find it difficult to believe the front 1/2 of the frame is different between 64 and 65. I could see the back 1/2 behind the seat post different for the new electric start inner primary for 65. (Background in your picture) Is it possible the tins need to be removed so you can get the motor in the frame and dropped down on the mount plates? Replying to keep you front and center, it would be nice if someone else could chime in here.
So cases are sitting down on front mount and pan tin on rear cylinder is hitting frame and keeping cases from resting in seated position on top of rear frame tab.
