Fuel Moto / Jackpot Mufflers USA's leader in EFI tuning and exhaust systems.
$995 Fuel Moto 107 EZ Big Bore kit now available
Old 11-26-2014, 01:10 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,108 Likes on 1,340 Posts
Default $995 Fuel Moto 107 EZ Big Bore kit now available
Our new Fuel Moto 107 EZ big bore kit is a simplified version of our standard 107" kit designed to work with stock cylinder heads and valve train on 96" & 103" Twin Cam engines. All components are top shelf including MTC forged pistons, Wood TW-555 cams, FM perfect fit pushrods, premium gasket set and more... For more info visit http://www.fuelmotousa.com/107-inch-big-bore.html
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old 11-30-2014, 12:41 PM
kylebryan's Avatar
kylebryan
kylebryan is offline
Are the only differences between this setup and the other 107 setup, lifters and adjustable push rods? What kind of power difference is there typically between the two kits?
Old 11-30-2014, 09:55 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
The difference between the two kits is the standard FM 107 kit offers a choice of cams, uses adjustable pushrods and also includes Wood's Directional Lifters. We generally recommend replacing lifters if the bike is a 2011 or newer with the factory C lifters, or if the motor has more than 10000 miles. Performance is the same with both kits.
Old 12-13-2014, 12:01 PM
brutalbrad's Avatar
brutalbrad
brutalbrad is offline
The EZ 107 has a compression of 10.25:1 but the other kit has 10.5:1 option won't this affect performance between the two kits?
custom Fuel Moto MTC forged pistons at 10.25:1 or 10.50:1 compression
Old 12-15-2014, 09:30 AM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Compression must be matched to the rest of the combination, the EZ kit is 10.25:1 as it is designed for stock heads and uses TW-555 cams. Our FM 107 base kit comes in either 10.25 or 10.5 compression to suit the different cam and cylinder head choices we have available with this kit.
Old 12-16-2014, 04:42 PM
G E E's Avatar
G E E
G E E is offline
Jamie , is there reason why none of the kits every come with new cam chain sets? At what mileage is it recommend to replace them? Do you have map for 107 in 2007 Flhrs with power commander 3 usb ,stage 1 a/c and VH Trur dual? Lastly do you have dealer in Flordia to tune it after break in?
Old 12-17-2014, 10:16 AM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
We recommend inspecting the cam chains and replacing them as part of the build if you have more than about 30K miles. We have a PC map we can provide to get you started, as far as dyno tuning we do not have anyone specifically we use in Florida however we do have Gary Williams in Pearl, MS
Old 01-12-2015, 02:10 PM
Big ACE's Avatar
Big ACE
Big ACE is offline
Jaime,
Do all of your cylinders come engraved with "Fuel Moto" on them??
Do you have a side by side picture of your cylinders next to stock HD cylinders?
Thank you,
Old 01-12-2015, 02:18 PM
kylebryan's Avatar
kylebryan
Originally Posted by Big ACE
Jaime,
Thank you,
they dont come engraved. You cant tell a difference at all externally that they've been bored out. The upgraded IC cylinders have the engraving on the side. http://www.fuelmotousa.com/ic-cylinders.html
Old 01-12-2015, 02:53 PM
Big ACE's Avatar
Big ACE
Big ACE is offline
I thought they all came engraved that way, Thank you!
fuelmoto
Vendor For Sale Classifieds
04-12-2018 10:16 PM
fuelmoto
04-24-2017 10:59 AM
Flying Horse
07-23-2015 08:02 PM
fuelmoto
11-26-2014 01:11 PM
fuelmoto
10-28-2010 11:35 AM
Quick Reply: $995 Fuel Moto 107 EZ Big Bore kit now available
