Just ruined a $4k custom paint job...
I haven't washed my bike in a while and I was trying to take the easy way out...used a pressure washer on it yesterday (to blow off all the bugs) and man did I screw up. I have a couple of spots bigger than a silver dollar on my front fender where I blew the paint off. I also have a spot on the tank where I blew a hole in the clear coat and it's starting to peal. Is there anything I can do to stop these spots from flaking/peeling off more now??? I'm concerned that they are going to continue to peel now. Then to top it all off, I melted a friggin micro fiber rag all over my exhaust when I was done...gotta clean that up too. I should have just left the damn bugs on there...
Wash the bike by hand from now on...
How fresh is the paint..How close did you hold the wand to the paint?
Received 3,389 Likes
Easy Off oven cleaner will take off the melted microfiber. Been there done that. Wear rubber gloves and cover the rest of the area before spraying.
Ouch. That's a tough way to learn that lesson; sorry it happened.
If it were me, I'd ride it over to a professional paint shop to see if they could work some paint-repair magic. I'm no painter so I wouldn't want to try to repair it myself; it would look worse than it did before.
You shouldn't have had that issue with a $4k paint job on a bike. Not by any stretch of the imagination. Much less multiple areas. Clear should not come under any type of automotive pressure washing....something like 3500psi might get some lifting if you held it a few inches away.
On to the issue of the peeling. You can coat the edges of the peeling clear coat with clear nail polish. it should go on smooth and stop the lifting.
Take it back!
Sounds like you got a $500 paint job for $4000. The paint should NOT have done that.
Yup, me too. Especially a $4K paint job. Sounds like the quality of the prep work wasn't very good.
In the future, wet a towel with really hot water, lay it on the bug areas for a minute, and they'll wipe right off... with no damage.
