HD Remote garage door opener
This may have been answered before, but I'm unable to find it. I'm not clear on the HD garage door opener kit. When you install the receiver in the garage, does it disable the factory remote that came with the garage door opener? If so, I assume you have to buy transmitters from HD to replace the originals. It appears, but the directions, that the originals are still functional but not very clear. I have one of my openers velcroe'd to the dash on my '14 Limited but I'm thinking about adding the HD system for a cleaner look. I'm not interested in any aftermarket system so please, only comment on the HD system. Thanks for any help.
Are you sure it comes with a receiver? Most of the vehicle kits I'm aware of just pair with the existing receiver. If this is the case, all your existing ones will still work. If it does have a receiver, it's going to depend on how they implement it.
A suggestion since you have the remote velcrod to your dash This what I did. Only cost was for the switch I put in one of the blank spots.
https://www.hdforums.com/forum/touri...ml#post4594153
Yes the HD opener will work with your existing equipment. What you do is plug the HD transmitter in to a power outlet then wire it to the push button switch in the garage, so it helps to have an outlet near the button.
However check out the flash2pass opener, it's easier to use and cheaper. I've used both and prefer the flash2pass opener.
I recently installed the HD opener. I wired the receiver to the opener itself and not a button, but where the button connects to the motor. My electrical outlet for it is about 2 ft. from the motor so it made sense. Everything works normally, even the programmed car button. I installed on a '14 SB, kind of a pain but got it done nice and neat. I found out with mine, if the lights are on hi-beam when you start the bike, the door automatically goes up. Doesn't if they are on low-beam. The thing about the HD model is it integrates with the bike controls and is all put away. Be aware you may need a wire harness Y pigtail, depending on your model.
factory remote
