NGK Iridium spark plugs
I went to Advance Auto for a set of plugs and the guy behind the counter had to go in the back to pick them off the shelf. He comes out with 4 plugs and starts ringing me up. I told him I only needed 2 and he said "sorry bout that, I thought Harleys took 4 plugs". So I went ahead and bought 2 plugs and headed home. So after I get home I start thinking if the guy didn't even know Harleys take 2 plugs could he have also gave me the wrong plug too? So I jump on Amazon and look them up and use the parts look up button on Amazon and it says they do not fit a 2007 FXDB Street Bob. Now I know Amazon has been wrong before so I guess my question is do any of you know if a NGK Iridium IX (DCPR7EIX 6046) will fit a 2007 Street Bob. Also do any of you run them in your bike and whats your opinion of them?
Top Answer
12-23-2015, 01:51 PM
Ok, a word of advice from a 50+ year mechanic. Everyone should get a jar of anti-seize and put a little on the threads of your spark plugs. Think about it -- if the plug gets stuck from being in there for a long time, the threads of the plug is steel and the threads in your head are aluminum. Which one will give up if the plug gets stuck? With anti-seize, it won't get stuck!!! Remember--- a LITTLE goes a long way--- don't give it a bath. Tip of the week-- lol
Use the "Part finder" link ontop of the NGK page.
http://www.ngksparkplugs.com/product...x.asp?mode=nml
To my knowledge they don't have an Iridium plug for motorcycles they aren't designed for it..
It's not needed anyways, overkill, even HD's high compression plug isn't needed with a stock engine,,
The following 2 users liked this post by FNGonaRK:
JustDave13 (11-09-2019),
Silent Glider (11-10-2019)
JayStronghawk (12-05-2019)
The following 2 users liked this post by GTK:
Cozz (10-29-2018),
Buy the standard plug from Harley. They last forever but 10K is a good ballpark since you do not want them to stick. Do not clean. REPLACE. Harley's ping systems uses the resistance and even the NGK that is the same as a Harley plug is off. I ran them and they did fine but I run flat country and never WOT or drive it hard. Use Iridium plugs for cars that go 100K between changes. However, I have a Honda with 200K on them and they run fine.
Do not fall for the bigger spark BS. My two set at 10K each. Think the knuckle head had 4 plugs. Probably one of the Harley engineers was from Datsun Motors
Mark out West (08-08-2019)
The following 2 users liked this post by Tampa Fatboy:
BigDawgQC (11-07-2018),
