How do you use throttle and rear brake at the same time in tight turns?
I read in the HOG magazine and on this forum about advanced riders being able to make tight low-speed turns by mastering the friction zone between throttle and clutch but also using the rear brake, which I guess allows even more slow speed control?
I've got pretty good control of the friction zone, but using the rear brake while using the throttle seems counter-initiative to me. How is it supposed to be done?
Go to youtube. View Ride like a Pro film clips.
In a slow speed situation.
Rear brake application causes bike to remain in a more vertical position (removes lean).
The application of power maintains this straight-up position.
The slipping of clutch or friction zone keeps the motor from turning off.
If motor was to turn off then a fall over could occur.
This application would most likely be used in a parking lot or u-turn.
