Rear brake question
Rear brake question
About a month ago I had a SERIOUS HARD braking incident where the ABS saved me. It seems as though I get some slight rough rear wheel braking and when not even using the rear brake it heats up. There was new pads put on at 27K in both front and rear calipers with the hard braking issue at around 30K and now I have 32K. I get no ABS indicator light, no smell of warm brakes, but disc is hot. Fluid is good to go. HELP??
Received 5,388 Likes
It only came about after a HARD stop but that was only 1500 to 2000 miles ago and has progressively gotten to how it is now in the last 300 or so miles. I wouldn't think that the one hard stop would of warped the rotor but!!! I don't notice it at highway speeds but can feel it when below 20 mph or so. Sort of intermittent too.
I had one set of Rear pads several yrs back that didn't last very long and would make the rotor hot when I'd ride...
The wheel would only spin about 1/4 to 1/2 a turn no matter how hard I'd spin it when I cleaned the wheel. Those pads only lasted about 10k and the next set I had put on the rear the wheel would spin a lot more easily when I spun the wheels during cleaning.. I could tell a mayor diff in the Drag on the wheel..
IMO it's as said above,, I don't think the wrench cleaned the brake pistons at all or maybe just not enough and they wouldn't release some of the pressure they were putting on the Rotors.
I've had 4 sets of pads on the rear and that one set was the only ones that did that.. as all the others have went 15K+ miles easy..
I have taken my front and back caliper apart and cleaned everything (pistons ,slides) real good with brake cleaner, re lube everything. Changed fluid at the same time . This was on my non abs bike. The reason I did it because the fronts were not releasing all the way and making a strange sound.This solved my problem .
Danny
