Ignition Switch Problem?
I have a 2003 Fatboy, last week when I started it I noticed my odometer was not working, and after taking off, my speedometer did not work. I stopped, switched the bike off and started it again and everything was working properly. It was ok for a few days and then it started doing it again. Now it does it more often, probably 50% of the time. Is this an indication of my ignition switch going out? Thanks in advance for any help you may provide.
I have to disagree about the VSS. You stated that you are getting no other symptoms so I'm assuming that the bike is running correctly and the signals are still self cancelling. If the VSS (speed sensor) was bad the signals would not cancel and if the bike is fuel injected it would not want to come down to an idle without stalling when coming to a stop. I'm not familiar with your model but are any indicator lights on the face of the speedometer (if there are any) working? If nothing is working (speedometer, odometer, indicators) than I would look for a loose connection at the speedo, a bad ignition switch, or a bad speedo unit.
