Springer rear caliper pin bolt stuck
The bottom pin bolt on the rear caliper of my 91 Springer is stuck and in trying to get it loose I managed to strip it out. It's a Torx bolt. I have heated it up and tried two different kinds of easy outs and it will not move. The top one came out easy. Neither one is rusty. I am assuming that both bolts turn counter clockwise to come out. Is this right? I have heard of people using a Dremel tool to grind a notch in the head to use a screw driver but I can't get a Dremel tool in there without grinding things I don't want to grind. Also using a hacksaw blade to cut a notch but can't get that in there either. I have also tried to grab it with a visegrip. This should have been an easy 20 minute job, but NOOO! What can I do now. Can I get the caliper off the bike without taking out these bolts? If I could get it on the bench I might be able to deal with it. Need help, want to ride.
Received 4,146 Likes
When my exhaust header bolt snapped on the Shovelhead, it broke off just under the flush line....
Tried various ez-outs...no love. Too narrow a bolt (hole) to do anything to give it a cut for a flathead. My buddy drilled it out...going progressively larger with drill bits until he was about to touch the threads. Real steady hand he had. Then we used steel picks...starting with one with a 90* bend on the end...to basically scrape out the remains of the bolt threads that were in the grooves of the threads on the head. Tedious work..but..it worked. Basically it would grip and you'd spin the pick along the threading..taking out half pieces and a few full twists of bolt thread.
Think dremel tool and cutoff wheel to make a slot, chisels just gonna make the mess worse. Oh do a few heat / cool cycles with a mapp gas torch before you get busy on it.
Old shop mechanic/machinist here. If I had to deal with that, I'd go to a large hardware, a machine shop supply house or online, and get a set of LEFT-HANDED drill bits, and a 45 degree countersink bit.
Use the countersink bit to make a nice guide indentation in the center of the bolt, Then set my drill for 'reverse' and use the reverse drill bits to drill on the bolt.
Since the drill is grabbing in the direction to remove the bolt, most times the drill force, combined with the heat and vibration of drilling will spin that sucker right out of there.
Start with a small drill bit and work up in size.
Good luck!
Good luck!
Good luck!
Good luck!
Received 3,222 Likes
