Low miles each year - need oil change every year?
I have a 2000 Fat Boy with 17K miles on it - basically averaged 1K miles a year. I have changed the oil myself every Spring but a Harley Tech told me I was wasting my money and I could easily go another season with the amount of rides I do. I know it is cheap insurance but feels like overkill every year
The bike sits on a jack all Winter in MN. Not sure if that has any impact on this but would appreciate your feedback.
Thanks
Thanks
pomeara (05-13-2016)
Water from condensation is the big concern here. Though I've never seen any in motor oil that gets hot regularly, tranny fluid seems to attract it (tranny oil only gets hot after a longer time.). Since your motor clearly doesn't get hot regularly, I'm with the change it every year crowd (but I wouldn't change the filter every time. That's a waste.)
Bring it up to operating temperature (oil, in all three holes, over 212*F) and then change the oil. You should actually be doing this every 6 months. Moisture in the air and the breakdown in the additives within the oil once it is exposed to air, and the moisture in the air (Boyle's Law and Partial Pressures, Google can be your friend here), are what contribute to this recommendation by every oil company and also Harley-Davidson. See your owners manual.
The Harley tech is probably right in that you could likely go two years, but you are doing it yourself, its an easy and cheap job so why not. As you said it is cheap insurance. I am sure you do keep an eye on them but another concern would be tires. Likely they will need replacing from age before mileage. I have heard some "experts" claim tires can go 10 years and others say 6 years. For me personally I would be changing them out at 5-6 years despite the wear.
