What rpm?
Depends on how many gears you have and the type of bike. When I had a sport bike it was around 3500 and I hear that a VRod is around that range or a touch higher. In my Fatboy with 6 gears I change around 2500 but to be honest I go off engine sound more than rpm it just happens to be in those ranges for me
3500 - 4800 RPM; I shift 1st to 2nd at 3500 but as for the rest, 4000 to 4800 depending on the situation...
Edit: I should add... those numbers are all predicated on the fact the bike is fully warmed up. Running a bike hard when they're cold is one of the worst things you can do to them... all those shift points are much lower until she's fully warmed up
More or less, I keep the cruising RPMs a smidge over 3k, so whatever that translates into from there.
If I'm getting after it a bit, I'll shift around 4,500 or so. Otherwise, something 3500 to 4000, depending. Occasionally I'll run past 4k, but on this bike, I just don't ride it that hard.
