New fuel pump change hoses ?
Location: Depends on who wants to know.........and why.
Received 1,901 Likes
I had fuel spraying in the tank, the front cylinder would only run on a small amount of throttle at 50 mph any thing more than that it would bog down. so i felt the spark was fine . when i removed the fuel pump and hoses i could not find the source of the spray . I even looked with a magnifying glass. the bike 50,000 on it and i like long trips . so to be on the safe side for $260.00 i will replace it and the hoses. My question is , should i replace the new hoses with the gates submersible hoses ? or has harley improved them ?
By the way, there is a pressure regulator in there that will blow off (spray) excess fuel when the system primes. This is normal.
I don't know if they fixed the known fuel line issue. If you want to replace the line(s) for fun, you can. If you do, use Gates.
I highly doubt your fuel pump assembly is your culprit. I would start looking at sensors and injectors. Could be just a dirty sensor. Are you running a fuel tuner?
Received 4,310 Likes
