washing your bike at car wash
do you wash your bike at the car wash?
if you do, how long do you let it cool off befoe washing?
or do you wash your bike with it running?
I mean its okay to ride in the rain, would it be okay to wash it while it
was still running?
was still running?
RE: washing your bike at car wash
Did it with my last harley about a dozen times. Have done it with the 07 once in 12,000 miles. Never hit it with the high pressure in what I feel is delicate areas. But it's great for getting the grime and dirt off the hard to reach places. Bike is usually warm but not hot. Car wash is close to home. Use common sense.
I've done this hundreds of times, without ever a problem. When I pull in, no matter how long I've ridden or how hot the motor is, I usually start off spraying the fenders first. Then the tires and wheels. I like to get in close and really spray the spoke area of the wheels. Then I usually spray the sides and exhaust. By then, the motor is cooled off enough to not hurt anything. But I don't use high pressure on the heads. Only on the side cases where there may be some grime. Lower pressure on the heads. About the only thing I don't spray directly on is the seat. It gets wet enough.
I've never had a problem w/ wheel bearings, even on older bikes (pre-1980).
ORIGINAL: green mnm
was still running?
was still running?
The suction from the engine intake could wash in a good gulp of water. Air is compressible, water isn't. The net result is a broken piston, at best.
I let it cool for about five minutes, to cut down the steam and let anyway the brakes cool down. Then I spray the rinse water on the hot parts to cool them down. Do not use soapy water or it will leave a godawful mess on the hot parts.
When it stops steaming, cool it down a bit more, then soap. Be very thorough on the bike bottom and aluminum parts, especially if you rode during winter. Salt can make a mess of your aluminum. Aluminum doesn't rust, but is very susceptible to alkaline corrosion.
Then rinse again, with the demineralized (osmotized) water if the car wash has it.
DO NOT use the rim cleaning fluid, as it's strongly alkaline (or acid, depending on composition) and again can and will mess up your aluminum.
DO NOT use the high-pressure jet, use only the low pressure one, and from at least 3-4 feet away, as it can penetrate the contacts and switches, damaging your electric plant. Switches and contacts are made to withstand water spray and splashes, not a high pressure jet. There is no problem at all using a waterjet cleaner, provided you use the low pressure jet and/or use it from such a distance that you have a water mist or gentle spray on the bike, and not a direct jet impacting it.
ORIGINAL: DannyZ71
Saved too long and paid too much to take a chance - good old hose, bucket, spongue and a buff and shine does it for me with a leaf blower to dry it off first. Anyway what better way (apart from riding) to spend a bit of time on a nice daythan tarting up your scoot being interuptedonly by the wife bringing afew cans of the amber nector to quench the thirst!
ORIGINAL: Gaffy52
Oh and +1 on washing the bike at home bucket and hose always cooled down and NOT running. Did that yesterday she's lookin' good today!
