kick stand spring lug
 \\; \\; \\; \\; \\; \\;&n bsp\\; \\; Hello- \\; I have a 2006 xl883 and I have scraped the spring lug for the kick-stand off my bikee by going off small curbs too many times. Now ther is nothing for the spring to attach to. Any suggestions??????
RE: kick stand spring lug
Is the problem with the lug on the kick stand or the other attachment on the frame?
 \\; \\; \\; The problem is on the frame. I had a machine screw threaded into the hole the first time it came off. Now the hardened steel screw is broken off in the hole on the frame. Should I weld a washer onto the frame. Right now I have it secured with a bungie cord which is dangerous....
Back in the day, would have just easy-outed the broken screw out of the frame hole and put a better bolt w/ a \\;wide head &\\; flat washer \\;in there and back on the road. \\; But, holes in frames can be kind of funny... the temporary machine screw could have started some distortion or \\;micro cracks. \\; Think I'd visit your (trusted!)-shop and see what \\;they say. \\; May be a weld repair in order if it is suspect. \\; \\;
crazytrain69
05-08-2009 09:27 PM
