who changes there own tires
just learned how too my nieghbor taught me. we changed out the tube first one got pinched so had to get another one. Ill never pay a dealer again it takes all of 20 min. I wont mind taking it in just for a balancing though. even though if i had a solid rim i wouldnt need too right? just wondering who else does this?
I just started changing my own tires. So far I've only done a front, but my back will be changed soon, not to mention both of the tires on my wife's bike.
As for the balancing, I do my own there too now. I bought one from Marc Parnes, http://www.marcparnes.com/.
It works great on a couple of jack stands.
balancing
There is a tool that has 2 cones that fit in your bearings and you sit the shaft on two jackstands. you spin the tire and the heavy point goes to the ground add weight on the opposite side and repeat until it dosn't have a heavy side.
Did this for may back tire and no problems. I think this was shown on the forum a few years back it was like $40. well worth it if you are doing your own work.
I changed my back tire. Used one of those marc parnes balancers. But have buddies who have been riding for 40 years that change their own tires and never balance them.
After the tire was off I use my 7 in bench vise to break the bead. Just have to be careful of the rim. I use tire irons but have used screw drivers on tires. Have to be careful of the tube when using screwdrivers though.
I have changed about 4 sets and I've never had to re-balance any of them. Just make sure the yellow dot (the light spot) is aligned with the valve stem. As far as posting the how-to, just do a forum search.
