marvel mystery oil? ever use it?
Old 06-09-2009, 06:14 PM
ctren's Avatar
ctren
ctren is offline
Never used it in bikes, but use it a lot for radio control nitro engines. Keeps them from seizing up when they sit for a while. Just put a couple of drops in after done running for the day....
Old 06-09-2009, 07:51 PM
frankjake's Avatar
frankjake
frankjake is offline
It sounds like MMO might be good just before putting the bike away for the winter.
Old 06-09-2009, 08:01 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
It comes in a can with great propaganda written on it proclaiming mysterious miracles, has a pretty color, and smells good. Other than that, I'd also guess that while it works for somethings, it ain't the cure all some believe it is. For every user that pours it in gas and oil like medicine and has never had an engine/fuel system problem, I'd guess there are thousands that have never used it and also have never had engine/fuel system problems.
Old 06-09-2009, 08:34 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,347 Likes on 3,281 Posts
Worked at Advance auto for a while and a lot of old timers and mecanics would say to use it in the oil about 100 miles before you change the oil and it cleans the inside of the engine...It's thin like gasoline so it would make sense that it would clean the inside of the crank case....
Old 06-09-2009, 09:58 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Originally Posted by xxxflhrci
It comes in a can
Where do you still find it still in cans?
I haven't seen it in cans for a long time, and it now comes in plastic containers.
Old 06-09-2009, 10:46 PM
Firebug's Avatar
Firebug
Firebug is offline
I have used it but use SeaFoam now.
Old 06-09-2009, 11:42 PM
mjvandal's Avatar
mjvandal
mjvandal is offline
I’ve always used it because the people I grew up with always used it. Without much knowledge or experience with newer bikes, I can’t say if there’s a need for MMO or not. I do know that old iron does like it. I add it to every tank when on the road and every third fill when in town. It really helps out the engines top-end. It’s not an octane booster and will not burn so this is one product were more is not better when it goes in the gas.
Old 06-10-2009, 01:11 AM
Donald A's Avatar
Donald A
Donald A is offline
Have used it in my Cummins diesel engines for years. Todays diesel is way low on sulfur and MMO provides some lubrication for the injectors as well as other engine parts.
Never tried it in Harley but may.
Old 06-10-2009, 06:15 AM
dog155's Avatar
dog155
dog155 is offline
Have been using Marvel for over 35 yrs.Buy it by the gallon it is much cheaper that way.It has many uses.
Old 06-10-2009, 06:58 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Da Gumpmeister is offline
BadBob, "Oh Ye of little faith" Bwahahaha
My Dad used it on our farm. I've been using it since I was a kid. I use MMO in the 'earl', cause I use Sea Foam in the gas.
Chit is AS GOOD AS Brylcreem "A Li'l Dab'll Do Ya"
In all honesty, given the quality and Fed standards for gas and detergent earl now days, combined with the 'modern' materials and machining of "machinery" (autos, etc), not sure it is as big of a deal, as it was back then. Sludge was an issue in the 50's and 60's, and previous(BUT I wasn't there, then ) to that.
Quick Reply: marvel mystery oil? ever use it?
