Typical labor hours for bar swap
Old 10-17-2009, 04:37 AM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
Default Typical labor hours for bar swap
Wife's Deluxe is at the dealer for accident repair and we're thinking of having them put a set of new bars on the bike for her. Something with alot more pullback.
Anyone ever have a dealer do it for them. Assuming new cables are needed what would be the typical number of labor hours involved.
I know I could do it myself but figure if I can get something crossed off my honeydo list for a couple bills it'd be worth it.
Old 10-17-2009, 04:52 AM
ToastedGoat's Avatar
ToastedGoat
ToastedGoat is offline
I've heard numbers ranging from 500.00 to 1000.00 from dealer changing out bars. A lot of it depends on what kind of cables/lines ect. Are you splicing the electrical wires or is there extension harnesses for that bike? running the wires through the handle bars for the cleaner look?
All this makes a difference.
I am putting some 14" apes on ,, new apes $50.00 (at swap meet).Braided cables and lines.....$278.00 . I'll do the work myself.
Old 10-17-2009, 05:47 AM
tjvrodrick's Avatar
tjvrodrick
tjvrodrick is offline
Better to take it home and you do the swap I don't let them work on my bikes....
Old 10-17-2009, 07:43 AM
stro1965's Avatar
stro1965
stro1965 is offline
I don't think you could get parts and labor for a couple bills, maybe $500.00? Think DIY!
Old 10-17-2009, 10:52 AM
Wallaby's Avatar
Wallaby
Wallaby is offline
Do it yourself, not that hard, save your $$$, plenty of posts on here to guide you.
Old 10-17-2009, 11:16 AM
oct1949's Avatar
oct1949
oct1949 is offline
I've read at least 4hrs, maybe more... so here thats $320 and up. labor only.
Old 10-17-2009, 11:24 AM
Aaron J's Avatar
Aaron J
Aaron J is offline
easy job, you can do yourself. Hardest part would be running cables through the bars, but there are a million tricks. I use a long shoe string and air compressor to blow that through the bar first, zip-tie it off on the wire bundle, wrap with elec. tape to hold the zip tie and shoe string on there and then yank through. solder and heat shrink, done.
Old 10-17-2009, 12:31 PM
2007fxdc's Avatar
2007fxdc
2007fxdc is offline
Had dealer do mine. Used existing cables but had them do internal wiring. Did at the same time as my 5K service. Took it to dealer instead of indy only because I had a 50% off labor coupon that kicked in only if I bought the parts from them. So, bought the bars and a new set of grips from the dealer, and got 50% off the labor for that and the 5k service. Total was 3 hours so I only paid an hour and a half. Probably the best and only really good deal I've ever gotten at the dealer.
Old 10-18-2009, 11:25 PM
Skidrow's Avatar
Skidrow
Skidrow is offline
I had my indy do some last week. It was a little over three hours for him.
Old 10-18-2009, 11:55 PM
RKKY's Avatar
RKKY
RKKY is offline
Actual labor time really depends on how many changes are necessary. I work at the collision center at my local dealership. Usually we will do upgraded parts at similar rate for what the insurance company pays for replacing the original part. If you need wires run internally and/or lengthened and new cables and lines then obviously some labor time is added.
Quick Reply: Typical labor hours for bar swap
