Rinehart vs stock pipe size ?????
Old 02-15-2010, 10:49 AM
mid evil train's Avatar
mid evil train
mid evil train is offline
Default Rinehart vs stock pipe size ?????
I bought a set of Rinehart slip-ons for my 09 SG. The add says they fit 95 thru 10 baggers. I just went to install them, and there is a huge difference in diameter between the Rinehart and the stock muffler. Do I need a gasket and a larger clamp, or different pipes? The length seems fine. As you can see the Rinehart is on the right.
Attached Thumbnails Rinehart vs stock pipe size ?????-rineharts-and-stock-pipe-001.jpg   Rinehart vs stock pipe size ?????-rineharts-and-stock-pipe-002.jpg
Old 02-15-2010, 11:08 AM
Glyder's Avatar
Glyder
Glyder is offline
Seems you bought a set that fits the Rinehart Tru Dual headpipes. Not the same size as stock headpipes.
Old 02-15-2010, 11:25 AM
mid evil train
Yeh, the add said they fit tru duals or stock. I e-maild the guy, I guess we'll see if he is a stand up guy, and does the right thing...I hope so.
Old 02-15-2010, 11:26 AM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
I think once you install them and tighten the clamp you will see the diameter collapse around the pipe and you will be fine. The inlet should be about 1 3/4". Do not know the diameter for true dual mufflers, but I think they are the same. As far as clamps. My opinion is you can reuse the stock clamp, but I the manual says to replace the clamps
Old 02-15-2010, 11:36 AM
mid evil train
I dont believe my stock clamp will even go around the Rinehart. I didnt measure it, but I think we are talking like a 1/4 inch difference in size.
Oldskewl
Exhaust System Topics
29
10-03-2017 10:45 AM
RickK
06-13-2014 08:52 AM
JimmyDee
10-23-2012 04:54 AM
dietdewboy
11-05-2007 12:56 PM
HilllBillly
06-19-2007 01:28 PM
Quick Reply: Rinehart vs stock pipe size ?????
