68 shovel deceleration smoke
hey guys.ive got a 68 shovel that ive owned for 27 years.had a s&s stoker kit put in it 13 years ago with no problems.took it back to the same very reputable shop to regasket the top end because of a cylinder base gasket leak.so they did a hone,rings,3 angle valve grind,new guides,and resurfaced rockers.now it smokes on deceleration.took the carb off.and it had a film of oil in head and intake.so i wiped it clean.put carb back on.started motor for like 3 to 5 minutes till i seen smoke.took carb off and there was a river of oil in there.it never had guide seals from the factory as most of you will know.so its back at the machine shop right now.im thinking maybe using jims guides with the viton o-ring and the crane.531 valve stem seals.i dont know why it would start smoking now when we just replaced the stuff with the same parts(just new)I know that if the rocker boxes get floded with oil that they will smoke as the oil comes past guide and valve stem.but why now and not before.gonna check the returns to make sure there clear.anyone ever had this problem??????I think im on the right track.any input greatly appreciated. C.C.
dont think so
these guys are pretty good.i dont think they would make that rookie mistake.plus i forgot to say this will be the third time apart.second time cometic steel viton gasket didnt seal so we went with a fire ring and milled head and cylinder.fixed that.and the oil is in the intake.if it were a wiper ring upside down.i dont think it would be getting into intake.wouldnt it just burn it and send it out the exaust?????thanks for the reply bro
www.shovelhead.us Introduce yourself over there. They live and love nothing but Shovels. Every answer concerning 66-84 motorcycles will be answered. And its the guides and seals.
i want to thank eveyone for the replys.im not so good on the computor so sorry that i didnt put any pics(have to get the olady to help there)and no i have not checked all the vents(like the oil tank and primary.but the crankcase is fine i know that much.im running a check valve made by azz for the last like 8 years that makes more vacum to pull the oil down out of the top end rocker boxes.going to the shop where the bikes at tommorow to get the heads off.im still looking at the guides and gonna put valve stem seals on.but anyone else thats had the problem im open to any other ideas.thanks again. C.C.
