I use the steam cleaner at work. Been doing it for years. You just gotta be 2% smarter than what your cleaning. Dont do stupid stuff and you ill be fine.
Yep, and the one I use has different nozzles. I put the one on with the lowest pressure.
I use the green nozzle. Between the heat and 3000 psi it does a great job. I use a caustic chemical on the fins to get the dirty rain residue off the silver fins in the winter. No amount of elbow grease gets that baked on road grime off.
