Nitrogen in tires
Old 11-14-2010, 08:40 PM
artz's Avatar
artz
artz is offline
hmmmm...... lets see.
Alot of effort to pump down the air out of the tire, then you gotta let it dry inside the tire, then go spend $50 to put the nitrogen in. Do you take the tires and wheels off, and deliver them to the nitro-fill dealer ? or do you let them dry out the tires or what ?
Alot of trouble to save a few hundred miles if you ask me.
Old 11-14-2010, 08:42 PM
OLD 96's Avatar
OLD 96
OLD 96 is offline
Received 2,235 Likes on 905 Posts
Originally Posted by asahi1234
I am planning getting a 2011 Road king Classic. My question is you can put nitrogen in car and pickups can you do the same for motor cycles?
Not worth the trouble.
Old 11-14-2010, 08:44 PM
Gruamach's Avatar
Gruamach
Gruamach is offline
And how exactly do they maintain a seal on a vacuumed, non-filled-up tire to keep the insides from being corrupted with air before the Nitrogen can fill it enough keep it solidly on the beads?
Old 11-14-2010, 08:57 PM
thealaskan's Avatar
thealaskan
thealaskan is offline
$50.00 LMAO !! It's pure snake oil. No benefit whatsoever. Mythbusters did an episode about this in fact = BUSTED.
Old 11-14-2010, 09:07 PM
wideglidebob's Avatar
wideglidebob
wideglidebob is offline
man what a gimmic i would advise you to tell your local station and all the staions you go to to carry it, otherwise as soon as you top off you loose all you have gained and as far as rotting tires do to water rotting inside that would take 20 yrs
Old 11-14-2010, 09:09 PM
rocknrick's Avatar
rocknrick
rocknrick is offline
No problems with nitrogen in the tires... just really dont want to pay extra for it.
Old 11-14-2010, 09:18 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Smile
I think the only way to keep your tires lasting longer is to don't put the miles on'em.
This is the bottom line.
Haven't heard how the experiments turned out using helium to lighten the loading. ;-)
Old 11-14-2010, 09:21 PM
CRASH69's Avatar
CRASH69
CRASH69 is offline
Once you put air in your tires forget about switching over to Nitrogen thats a waste...Crash
Old 11-14-2010, 09:45 PM
Then Came Bronson's Avatar
Then Came Bronson
Then Came Bronson is offline
Received 1,961 Likes on 744 Posts
You certainly could, but why would you?
If you're flying a Boeing 747, then nitrogen is a must in your tires. On a normal, everyday car or motorcycle, it isn't necessary. Your motorcycle tires are not going through huge temperature or ambient pressure changes, nor do your tires have fuses. You're not worrying about the tire exploding because of a small amount of O2 in the compressed air auto-igniting during an aborted takeoff, or a max effort landing.
Stick to compressed air for your bike...it's plenty good enough.
Old 11-14-2010, 10:16 PM
2whlr4life's Avatar
2whlr4life
2whlr4life is offline
Received 2,439 Likes on 1,401 Posts
Arrow O.c.d.
I see very little need of Nitrogen in motorcycle tires. I believe its Hyped. My problem is that I'd keep checking the tire pressure regularly. Everytime I check my tires I always lose a little bit of air, sooner or later my tires would need more Nitrogen. For me, little benefit.
o.c.d. obsessive compulsive diease
o.c.d. I think u get the picture
Quick Reply: Nitrogen in tires
