Need urgent help removing exhaust stud (not broken)
I posted something yesterday anticipating difficult, and sure enough it is giving me problems. When removing my headpipe, one of the exhaust studs got cross-threaded. Although it was hard, the nut came off without breaking the stud. But both the nut and stud are completely unuseable again. So now I'm tasked with getting the stud out of the head. I need some help here. It is the rear/upper stud, so there's not a lot of room back there. There's no way of double-nutting it, as the threads are thrashed. I briefly tried to use a good pair of vice grips, but it's difficult to get a hold on the stud in the cramped area. And the stud doesn't seem to be moving at all.
What do I do here? I expected this to take a few hours for the complete job that I'm doing (removing cat), but this may turn into a major issue if I can't get that stud out.
HELP!
HELP!
How bad is the stud? can you get a die on there to rethread or a thread chaser to re cut the threads ..and then double nut it and remove ? If you can start the die by hand you can then turn it with a socket .......
Received 47,790 Likes
HELP!
HELP!
I just wanted to drop a quick note and say THANK YOU for all of your suggestions. Although I have access to a mig welder, I have never welded, and I did not want to test out my skills on my bike. So I was hopeful that heat and vice grips would do the job. And thankfully they did. The only item that I had to buy was a small pair of vice grips, as all of mine were too big. It took me several attempts, but I eventually heated it up to an adequate temperature and I was able to fight it out of the head. No galling either. Put a new stud in with a coating of nickel anti-seize for good measure.
BlackFLHR
07-29-2011 10:56 PM
