Headlight Bulb?
Headlight Bulb?
Hi I was wondering does anyone know what the brightest bulb is that I can install in my stock HD headlight housing on a 2005 electra glide classic?
or can this not be done?
Thanks
Thanks
I use a PIAA extreme white bulb. It is brighter as stock using the same wattage. Just be sure to use a 55/60 watt bulb or it will likely melt the plastic reflector.
https://www.hdforums.com/forum/touri...ad-lights.html
They are the brightest bulbs I have ever run. I use them in my truck and most of my cars. Great bulb, I can see so much better with them! They will set you back around $20, and the store will give you your money back if not satisfied. But I think you will definitely appreciate them.
Well thanks for all the info here guys Ive read them all and have been doing some research as for the truck-lite option that is not an option $315.00 for a bulb is insane.....so with that said what are my other best options? Im willing to spend up to $100 if that means just changeing out the bulb or changeing the bulb and the glass.......what im after is the clearest most white/bright light set-up I can get for a $100 or less in a plug and play method without causing any burn/melting issues sorry for the post But please care to chime in with that set-up and post the manufacture and part numbers please I will be sure to post what I decided to go with.
Thanks
Thanks
I can guarantee this bulb's one of (if not the) brightest on market (4th bulb down, H4 80/100 Osram): http://www.germanautoparts.com/Hardware/Bulbs/H4
This baby sheds lighe everywhere & I've been running for 2-yrs now w/no problems. Leave it to those crazy Germans
They are bright, but they seem to have an awful lifespan on bikes, I think its the vibrations.
