too much oil in transmission?
I have just completed the 5000mile oil change on my 2007 Ultra classic. This is the first time I have done my own oil change and this is my second Harley. When I changed the oil in the transmission, I let it drain completely and then added 32 ounces as per the 2007 service manual. When I checked the level on the dip stick it was over the top line by about 1/4". I rode the bike for about 10 miles, checked it again and it is still the same. Is this O.K.? Should I drain some out and bring it half way between the low and full marks? I did the checking and filling while the bike was on the jiffy stand. Thanks, Halfbreed
RE: too much oil in transmission?
I did the exact same thing when I did my tranny fluid the first time. My problem was trying to approximate the right amount of ounces out of the bottle and put too much in. I just drained out the excess and was good to go. After that I bought a measuring cup and use this to make sure I put the right amount in.
If you put too much in,guess what,as soon as you start it,it will foam and spit out the trans overflow tube.
1 Post
ORIGINAL: DougsDyna
Did you screw the dipstick back in the hole? Should just set dipstick in hole Do Not thread it in. ... Should be on Jiffy Stand. 32 ounces
DougJ
DougJ
Received 4,368 Likes
to tombeving, my 05 owner's manual calls out for 26 ozs. for the capacity in the primary case, did theMOCO change something?
ORIGINAL: JGroves
This is the correct way to check the fluid in your Transmission.
ORIGINAL: DougsDyna
DougJ
DougJ
