HF table lift fell over, with the bike on it
First time I have used the table lift. Have the 2011 FLHTK on it to remove wheels for tire replacement. Put it on 2 days ago, have a 6x6 under the rear of the frame to support it, ratchet straps on the front from the fork tie-downs to the lift. When I removed the rear tire, used scissor jack to raise front end and then blocked it with wood. Sat 2 days like that, raised to the highest level using the lock bar. Today put the front tire on, raising and lowering the bike on the lift with the scissor jack. Re-secured the front straps firmly, still have the original wheel vice on the lift. Install the rear tire, raise and lower the lift a couple time to get the tire on. Finishing everything up, just checked the tire pressure, sitting on a stool on the right side and the bike, with the lift attached tips over to the left. I had constructed 2'x6' by 6" high side extensions which were off to the side about 3'. Bike landed on the side extension and a roll of carpet against the wall still attached to the lift in the front with the ratchet straps. Saddle bags were off thankfully.
Twisted in the angled foot peg "bending" the left front lower. No other damage. I moved the peg back out and the lower sprung back into shape. It landed on the end of the left handle bar on the plywood, heated grip rheostat.
Pretty horrifying to watch the lift and bike fall over. Don't know how I lucked out that nothing was where the tank would be. Trying to figure how it could happen. Thinking that the wheel vice, yes it was tight, won't hold the bike up straight like a wheel chock. I have a wheel chock, the HF $35+- one, but since I was going to remove the front tire figured the vice would be easier. The lift didn't break, everything was sitting 90 degree to the floor. I used a sizzor jack to raise the bike on the lift for wheel removal and had just a few minutes before removed it. The jack would hold the bike level, with it gone, it allowed it to tip over. I also ran my front ratchet straps pretty much straight forward and down to secure the front. I need to add a corner tie-down hook so the front straps have side forces also. I had removed the rear straps since I was raising and lowering the bike for the rear tire install. Should have put them back on.
I also don't think I'll use the highest setting. Too top heavy center of gravity. I'll also leave the scissor jack in place until the bike is lowered, the side extensions are in place and the kick stand down. And I'll install the wheel chock and get rid of the vice.
So that's how my day went.
Oh man, sorry to hear that. You're lucky, it could have been much worse. I've always been leery of them myself. I could see how a 900 pound bike could fall over like that. I'll keep using my jack to lift my FLHTK.
I suppose anything is possible but I'll take the precautions I listed.
And I'll lower it over night with at least 4 straps that have side pulling.
Bolt it to the floor. Use lead shields in the floor and lag bolts. That way you can remove the lags to move it, and nothing will be sticking up. That's what I did with my chock.
Received 1,211 Likes
The wheel vise may or may not hold a bike in place. And once it starts going over it ain't stopping. What I've seen with mine is that the vise will do OK on a 19" wheel, but it just doesn't feel comfortable with a 16". Unless I'm using my home-made 2x8 or 2x10 jack-lift under the bike to do a wheel removal I always use the tie-downs.
I agree with IAMSWUTIANS - bolt that thing to the floor when you are using it. I have 4-1/2"anchors in the garage floor to bolt my chock down with. when i finish it all comes up and I put 1/2" button head bolts in to keep dirt out of the anchors. The round bolt heads are not a trip hazard.
Glad that it didn't cause any serious damage to your ride.
I was expecting to read about a mini disaster but glad to hear you lucked out. I've never owned one of those type jacks but it seems that bolting it down would be mandatory especially with the bike being strapped to the lift which would make the whole assembly top heavy and prone to tipping.
